Drivers side A/C blowing warmer than passenger side
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
dbaxRonin
Car: 2016 Infiniti Q50 Red Sport 400
2010 Infiniti G37x AWD Coupe (Traded in)
2001 Infiniti i30L (Traded in)
During this recent heat wave, noticed that I haven't been getting really cool a/c coming out of my vents. Chalked it up to how hot it's been (90f+), but just noticed today that the a/c coming out of the passenger side is noticeably cooler than what is coming from the drivers side...don't have specific figures, but it is by a number of degrees cooler. Closed the passenger vents (and backseat) but the drivers' side doesn't get any better. Tried between dual and single control, again, no difference. Toggled between recirc on/off, same result.
Anyone ever run into this?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's a bulletin about it, ITB16-037c. The link arm for the driver's mix door needs to be replaced with a redesigned version. The job is awkward but not tough, no need to remove the dash.
https://www.infinitiq50.org/attachments ... pdf.89433/
That was my knee-jerk response. Blend door isn't functioning properly.
dbaxRonin
Thanks VStar...seems like that would be the culprit. Appreciate the assistance!!
VStar650CL
Technical Expert
Happy to help, you're most welcome. Happy motoring!
VStar saves the day.... All day, err day. :)
Return to “Infiniti Q50 / Q60 Forum”
