Welcome!
After a little research, it appears it's the cable that runs from the door lock switch that is broken.DCaff300ZX wrote: ↑Sat Sep 01, 2018 6:05 amWelcome!
Probably a little clip, check out the "everything you need to know...Z32" sticky for the online service manual, which is your best friend for such questions and solving problems with the Z32.
Sounds like you will be there a lot if as you say it needs a lot of TLC, as most/all Z32's do...Good Luck!
Try Concept Z Performance, or Z1's used parts if CZP can't help.gioguy21 wrote: ↑Sat Sep 01, 2018 4:13 pm![]()
Welcome!
Does anyone know what kind of part this is specifically or where to buy?
