qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Fri Oct 19, 2007 6:51 pm
The window mechanism is basically two parts, the motor and the regulator. The thing with all the pullies and cables is the regulator. The window bolts to it with a couple 10mm bolts. You take out the speaker and pull the whole regulator/motor assy out through that hole and swap the motor to the new regulator while it's out of the door.
Just be careful with the window after/while you are unbolting it.
