VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Jan 06, 2022 6:12 pm
You're always best to reconnect the switch with the inside trim still removed and test it before completing the reassembly. Before that, right after the pane is reinstalled, feel for the front and back edges to make sure they're in the channels and not displaced. When you "miss", it will usually be at the front edge. The pane will drop straight onto the regulator guides and line itself up if it's inserted properly. If you need to "jimmy" the position to line the holes up, then chances are the pane is out of the channels.
