Driver side won't control any of the car windows
Gurthy
Car: 2001 Infiniti QX4 3.5L 4wd
This post is pretty straight forward. I have a 2001 Qx4, and the driver side window control just (all of the sudden) stopped working.
I can't roll down any of the windows in the car from the drivers side (obviously including the drivers side window). Does this sound like a motor issue. Do connections in the motor need to be cleaned?
I remember in my old 1992 Toyota 4runner the connections would get dirty, and would just need a little scrub. Has anyone heard of this with Qx4's?
In addition, is there an easy way to access the motor. The driver door panel looks extremely protected, and the motor looks difficult to access.
Thanks to all for any info
bmlawless
Car: 1999 Infinity QX4
If none of them work, it likely isn't a motor issue. Not to sound insulting, but are you sure the window lock button isn't pressed?
Gurthy
Yeah... I'm sure. Nice thought though.
It it fairly easy to access the switches to see if something is broken?
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Gurthy wrote:Yeah... I'm sure. Nice thought though.
It's dead easy, if it's like my '02 Pathy.All you need is a flat blade screw driver.Just pry up the switch pad assembly with the screwdriver, and it should pop up.My son's Subaru had the same problem BTW, and it was a loose wire in the harness at the switch pad. Therefore no power. Took 5 minutes to fix.Let's hope yours will be that easy. Good luck.
Gurthy
I tried to access it and I didn't get the piece to pop up. Does anyone have a link to a manual or diagram on how to access the switches.
I don't want to mess up something permanently
Gurthy
Alright... I was actually trying to yank up the wood. (idiot )
Finally when i got the switch up, one of the connectors wasn't plugged in... must have just fell out over time. Plugged it back in. Everything works fine.
No money spent. Sweeeeeet!
Thanks for help guys!
bmlawless
Hooray!
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
We totally need a way of letting users report how much money fellow members have saved them. I can easily see a stealership charging a couple hundred for this alone, and this is just one thread out of over 400,000.
