driver side window wont work!!!
DawgMode
Car: 180sx
wassup i got a problem
my driver side electronic window in my s13 wont go down.
what happens is when i hit the down button, u hear the auto down relay click but nothing happens then after a while it will go down....but only wen the car has been baking in the sun all day ...but wen it does go down, it wont go up and when i hit the up button the relay doesnt make any noise and nothing happens, so to get the window to go up, i have to pull the door panel off and pull the plug out of the relay and play with it then put the wires back in and if im lucky it will go up.
what do u think is wrong????
DawgMode
Car: 180sx
anyone?
Rusted_PS13
Car: 1991 Nissan 240SX
I have the same problem...except mine only went down once. But, on other threads that i have read, it's either the little black box under the door panel, which i think is called the amp. You might wanna try replacing that.
DawgMode
Car: 180sx
yea thas wat i think it is
