4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Sat Sep 17, 2011 11:35 pm
I just swapped regulators in my drivers side manual window. Mine's an S13 so I hope they are similar. I'm also going to assume they are similar manual to power. Take the door skin off first then the plastic sheet. The window is bolted onto the regulator bracket in four places, two on each side. with the window nearly all the way down you should see the 4 (10mm?) nuts that hold the window on to the track guides. I'm guessing one side maybe loose or has come undone. Check the 4 12mm nuts that hold the regulator bracket to the door, maybe those are loose. There are also stops at the top of the door that are adjustable by loosening the 10mm nuts and sliding them up or down a bit, but these are for adjusting final "window up" positioning to get a good seal on the gaskets. Hope this helps.
