driver side window motor died. help!
gdamimgoodlookin
Car: sleep
The other day my driver side window motor died. I called nissan and they said list would be $440 just for the new part, plus intallation. is there anywhere i can get the part cheaper, and install it myself? I need to get it done soon cuz im gonna go on 8 hour road trip in the middle of summer and i need to roll my window down....man, i really need some help on this!
'95 240sx
skillzilla
If the window just stopped working, but the passenger window still works from the drivers side, its probably the window relay. Take your doop panel off and look for a black box with a plug coming out of it towards the rear of the door. Replace that and see if it helps, cuz I was in the same situation as you and that $25 box fixed it all. Ive also heard they go out quite often.
gdamimgoodlookin
Car: sleep
thanks alot, do you by any chance know where i can aquire that? should i go to the nissan dealership or will they ripp me off...thanks again...
skillzilla
I got mine from a junk yard. Im sure Nissan Dealerships will all have them, they are standard on all their power windows from what I can tell. Any junkyard will have one though.
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
hey. i have the same problem... mine is 96 though. any way to test teh relay?
reds14
Car: working on my car
My window motor is also out and I have searched for months for a new one and the only two places I have found are NAPA-$105,and http://www.nationalpartfinder.com-$105. Through NAPA I get huge discounts so there origanal price may be higher but the national part finder has the list as $105. Those prices are for the s14 because they are totally different than s13. Hope this helps.
