Driver side Window glass stuck
maddieQ
Car: Q45 1994
Hi,
Just when Im dealing with the intermittent stalling problem.. this happens!!!! I pulled the driver side window down at a light, half way down I hear a grind and a clunk!!! the window is stuck!! next i try the switch again it moves .. goes down ... and stays down. I can hear the whirr of the motor when i move the switch but the glass does not move. Is this a DIY job?? Anybody done this before?? I think its a mechanical failure. How do I remove the doors side panel to take a peek inside.. Help guys.. this tub is slowly siphoning my greenbacks out of my wallet!! I was planning to take my family out for the weekend.. :-(
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its the window regulator
What you can do to get it back up is put something on the rail, like a small pair of vice grips to hold it up until you can replace it.....
to take off the panel, slide back the armrest, 3 screws.. THen carefully take off the thing with the seat controls... one more screw i think, maybe two.... Then just carefully pop off the clips.....
maddieQ
Car: Q45 1994
Thanks Wes.
Could you give me more detailed instructions? I aim to do it ASAP. Do I need to replace the window regulator??
Thanks again
maddieQ
Car: Q45 1994
Got it on this website..
http://www.carstereohelp.com/s...e.htm
From the posts I searched all point to the regulator. Now I need to buy an MAF and a regulator. Dang. Is anybody selling these ?
3rd Q
Maddie,Got one for you. If it is the driver's side you need, good news- the one I have for you was put in nerw about 2 years ago. Email sent w/details.Paul
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
maddieQ
Car: Q45 1994
Managed to get the glass up. Had to move the switch up and down and push the glass up manually. Did it some 10-15 times and the glass going up higher each time. Finally snapped into place ans stayed there. I have bundeled some plastic and paper and jammed the glass in place so that it does not come down. I need to probably re-open when I replace the regulator. Another weekend and 3 hours of work maybe.
Question: Is the white plastic piece I found part of the regulator???
I have attached the phioto of the door with the panel removed.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Plastic piece is very likely a part of the regulator.
whitcre
Car: golf, cars
mine broke last week. bought one from junkyard for $50. took about 2 hours to remove and replace. lot easier than i thought. maybe 8 screws after i got panel off. plastic part is part of cable guide, i think
