driver side window and door handle
zinginaround
Car: 1995 j30
My 95 j30 driver side window doesnt stay up - I can hear the motor running, I am wondering if I can take the door panel off and hook up the control arm or something - in addition the door lock and handle quit working about the same time some times the lock and handle work and sometimes not, there does not seem to be a constant that I can track. It works some days with the key in the lock and somedays with the remote. Some one creased the side while it was parked so I am wondering if that could have caused the failures. And one more thing why would the tack all of a sudden jump over in the red, not at any particular time, just does it, not every day either, I dont hear the engine or transmission change.
colincliff2
Not sure about your window issue, but there have been several others on this board with door lock / door latch issues. When it's just one door giving you trouble, it's often the lock actuator and/or door latch failing. Here are a couple of resources for that issue:zerothread/261142http://www.fuzzycats.c ... _locks.pdf
zinginaround
Car: 1995 j30
Thank you, thank you! I think I can do the lock myself - otherwise I have 5 sons one of them might be able to do it for me - thank you again.Barbara (zinginaround)
