driver side window acting funny
GuSpeed
Hi guys.. so my driver side window is a power window and it sometimes rolls down and sometimes it doesn't. It will roll up because you can hear the motor when pressing up. When pressing down it doesn't do anything...
I bought a new switch on ebay and it does the exact same thing. Took it apart to clean and still same thing.. I'm not sure what to do next.
Thank you.
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
fuses or circuit cables..>
OMSIN
Car: 1993 240sx Coupe SE
I'm just guessing, but you window motor could be going out. I've only owed 1 car it didn't have power windows nor have I delt with another car with power windows, there for no experience.
sr20power
Car: S14 Zenki
Well I don't think its the fuse if it sometimes rolls up. But it could that your relay is going out or that your wire could be pinched somewhere. A friend had the same problem and I found the problem where the wire passes thru the door jam.
