What I did:
- Followed the tightening sequence in the FSM
- Used the RTV stuff on the 2 small grooves in the back and the one on the front. Not sure I used enough.
- Cleaned all surfaces
- How much of the RTV stuff should I use?
- I did not remove the intake or the throttle body and had to slide and angle the cover. Should I have removed these to make the job easier?
- Some of the posts here mention a plastic piece/rubber piece that should go in the rear groove. I do not recall seeing this piece (will check under the car tomorrow). Should there be one or 2 pieces? If one, does it go in the bottom groove?
- Shouldn't the gasket and silicone be enough seal the groove?
Thank you!
