driver side parking lights
pinky121388
Car: 1992 Nissan 240sx convertible
they dont work, but the front and passenger side works. the two that dont work are the orange and red lights on the side of the drivers side. whats the deal?
94_240sx
Car: 94_240SX
Replace bulbs first and see. You can remove front side marker if you push to one side and pull. Rear one, you have an access from inside of trunk.
pinky121388
ok i'll that one a look.. i dont know if the bulbs went out, if they did wouldnt all the parking lights go out
S-13
Car: 93 Nissan 240SX
pinky121388 wrote:ok i'll that one a look.. i dont know if the bulbs went out, if they did wouldnt all the parking lights go out
no. Its possible for each one to burn out independantly from one another. I dont think its wired in a circuit if thats what your asking
waitn4sno
Car: '93 Nissan 240SX Vert 5spd
'09 Nissan Titan
Sorry if I am threadjacking but, I want to swap my four lights for clears. I see lots on ebay, but only refers to "Front" side markers. Can I use them for the rears as well?
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
pinky wrote:ok i'll that one a look.. i dont know if the bulbs went out, if they did wouldnt all the parking lights go out
These cars are old, but they're not strung up like christmas tree lights
waitn4sno wrote:Sorry if I am threadjacking but, I want to swap my four lights for clears. I see lots on ebay, but only refers to "Front" side markers. Can I use them for the rears as well?
I want to say no, but only because the front's are removed differently than the back, so I think they are shaped differently
94_240sx
Car: 94_240SX
Loki wrote:I want to say no, but only because the front's are removed differently than the back, so I think they are shaped differently
If you really want, you could try to heat it up with heat gun, take it out and swap red reflector with clear one. Or there's got to be a way to swap them.
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
My clear front side markers should be in soon and I'll see if it's the same opening.
biggie
I was thinking that the front and rear are the same shape, just flipped upside down (tab towards the front on fronts, tab towards rear on rears). But its been a while since I've taken any out.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
94_240sx wrote:If you really want, you could try to heat it up with heat gun, take it out and swap red reflector with clear one. Or there's got to be a way to swap them.
x2. As a last resort, you could even silicone seal them on... but I don't see why they wouldn't fit on the rear. When I had them all out, they looked exactly the same size.
S-13
cmkelly wrote:My clear front side markers should be in soon and I'll see if it's the same opening.
let us know if their interchangable. I may be doing this in the near future as well
waitn4sno
'09 Nissan Titan
Popped my side marker out of the front, & unbolted the rear one today to see if they are interchangable.My rear side was held by two nuts threaded onto stems attached to the back of the marker assembly. There was a wack of Butyl tape in there to seal it in place. My front marker was clipped in (tab in front), no hardware & no butyl junk to seal.It appears the front unit will fit nicely into the rear hole, just need some sealant to hold it in place.Has anyone else taken a closer look??
