driver side light does not flip down
stacy
Car: 1990 nissian 240sx se
does anyone have any idea what i should check first. I already checked my grounds n the light gets power because it flips up but it does not go down
180fan
Car: 89 fastback
is there power going to the motor?
Usually the switch (stalk on steering wheel). Common part to go bad on a 240.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
There is a good chance the headlight motor is defective IF the light comes down by itself after a few seconds. Bad connection. The connections inside the motor get dirty and affects the flow of current. Take motor out, take apart, very carefully!!! and clean the inside with contact cleaner spray. IF it stays up, then look at switch in the steering wheel.
stacy
alright ill try that then
