Driver side high beam light stuck on
J30inthe sun
Car: 1997 J30
Sometimes when I turn the low beam lights on the driver side high beam comes on as well. When I turn on the high beams then the passenger side comes on & turns off when I turn the high beams off (the passenger side fuctions properly with the switch).
Also it seems to be an intermitten problem, it doen't always happen.
Anyone have any suggestions?
Q45tech
Replace headlight relay module as explained in FSM.............common failure more common if non oem or aftermarket bulbs are used for replacement.
93jdirty'
Car: 1993 Infiniti J30
Dont know if it helps but there was a time only my highbeams would light not matter what even if i had the lows on. It was because a fuse under the driver side dash.
driverdriver
Car: NICO's longtime resident Canuck!!!
Always use the correct voltage bulb (55w) anything above that will screw up any one of a number of headlight components or fry the wiring.
TC_EmCee
im having the ame problem my high beams are always on. i thought it was my control switch but havent done anything yet, where is this fuse you speek of i have looked under the dash and havent seen anything
yodawill2000
Car: 94 Infiniti J30
Fuse panel is on the drivers side kick panel.
