I dont think there are child locks on the drivers door. But you might want to take the door panel off and see if the link is broken or it just might need some lube. Also spray some white lithium greese in the locking mechanism to make sure the problems not there.allensteiner wrote:did you take the door panel off to check? you said the lock linkage moves normal but the handle doesn't come out as far as normal your child lock on???
