30bino09 »
https://forums.nicoclub.com/30bino09-u65360.html
Sat Aug 15, 2009 5:08 pm
Hi Guys I drive a 1994 Q45. Recently my driver seat stopped sliding back and forth. All other seat switches work (head rest, recliner, up/down seat adjustments, lumbar support etc etc). I need to know if it's a slide switch problem or if the motor under the seat is gone. The two indicator lights on the memory switches are blinking continuously even when I turn off the ignition. I checked the service manual and all switches controlled by the "LCU01-A" connector in the LAN circuit diagram work except the sliding switch.
I have also been having audio and illumination problem for a while. Example. My stereo (the original stereo) volume comes on a off sometimes and sometimes it's scratchy then clears up. Sometimes when I turn left it goes low and if I raise and lower the window it comes back on full volume. Also the little green illuminations on the window control switches by the gear stick come on sometimes and sometimes not. They are mostly off.
any suggestions
Modified by 30bino09 at 8:16 PM 8/15/2009
