Driver's window auto-up?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
2013 Gen 1
I know I saw it here but can't find it now. After battery disconnect or replacement you lose the driver's window ability to go up with one touch. Nothing in the OM. Anyone recall the procedure to re-learn this? I think I remember turning the ignition off and on with the door open or something. You guys know? Thank you gang...
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Not that it helps, but I can change the battery and disconnect a dozen times and don’t lose the capability of window going up with 1 touch on my 2009. :gotme
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The ones with a mechanical limit-switch in the window motor don't usually lose their brains on a disconnect, but they're complete PITA's when they do lose it because the door panel has to come off to reach the reset button. The later models with encoders can lose their brains, but resetting them is a lot easier. Just run the window all the way down, then all the way up and hold for a few seconds at the top (Nissan says 2, but I always allow 3~5 to make sure). I'm not sure what's on an '09, but I know for fact a '13 has the encoder type.
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
VStar650CL wrote:
Wed Apr 20, 2022 7:58 pm
+1. I can confirm this works on our 2015. I have had to do it 3-4 times in the 7 years we have owned it. I wrote it down on a sticky note and put that with the manual because I could never remember what to do when it reoccurred.
phmichel
VStar - you were right. Easy Peasy. Thanks again friend...
VStar650CL
Technical Expert
You're most welcome as always. Happy motoring!
Return to “Rogue Forum”
