Hello, I had addressed the root issues (tune-up mostly) related to the 2 of the 4 clogged cat converters by replacing the front & rear 2 cat converters on the passenger side so it would pass overall and emission inspection on my 1994 Q45.
I didn't do the driver's side front & rear cat converters at the time due to the VERY tight space for the welding of the front cat convert per my mechanic. Althought I passed the inspection without the 2 clogged ones, I want to replace it next for environmental reasons. This week, I found the whole passenger side exhaust setup that contains the 2 cat converters where it goes from the engine's 4 exhaust manifold pipes to the pipe contains the 2 cats from a local used auto parts yard.
The image may looks something like this
http://images.google.com/imgre...a%3DN
Flash lighting into the cat converters shows no clog so it's looks good for me.
Question: in your view, how many billable hours should the shop charge me for the labor to replace the setup I found at the yard?
Thanks!
