ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Feb 28, 2011 9:16 am
Did you verify the width of the pads before trying to put them on?
Did you take the overall width of the front discs before re-assembly?
Did you remove the calipers completely and verify the rear of the pad mounting clean, lubricated and verify the piston travel with clean surfaces, seal points, and piston all the way back?
Did you have to open the hydraulic system bleeders?
When assembling did you lubricate the bolts and verify that the caliper is able to float?
Did you dress the disc surfaces?
New pads on existing discs will need time to match and mate up with the 2 surfaces of the disc and the pad.
I cannot answer your question because from what I read I have no understanding of what you actually did, but I realize you had difficulty.
