joser »
https://forums.nicoclub.com/joser-u104333.html
Sat Aug 23, 2008 12:46 pm
Had the same thing happen on an Xterra. It was a nickel that fell down on the right hand side of the seat through the gaps. Seat got moved all the way back by my dad and it got stuck. There are four bolts holding the seat down to the floor of the car. They are easily removed, and you can take the whole seat out of the car and put it upside down to have the coin fall out. I had to loosen the coin a little bit with a flat head screw driver, but it came right out. There is a cable connected under the seat for the seat belt detection. In order to remove the seat, you need to disconnect the cable.
