ok... so I got around to finally taking out the bulbs... and it's pretty clear that the bulbs are the issue, not the ballasts. I have a question... it's obvious that one or both bulbs are not OEM... the question is which? The one with the greyed gas capsule is obviously the burned out one... that is made by Phillips.... the other is not marked at all....
The bulbs are also shaped differently... why does the Phillips bulb have an extended tip for the electrode? Also, why does it have these metal clips at the base?
I should mention that I have still not received the bulbs I ordered yet... shipping issue... or perhaps they broke in transit... I got the seller to send me another pair...
So, If you're anything like me, you cannot digest wheat.... no, just kidding,
If you are like me, then you've decided to protect your Q with an aftermarket alarm... the problem is that I took the battery out and don't want to put it back in until the new bulbs are installed... might be another few days, but I decided to get a head start because
Curiosity killed the cat, it left me alone. Sooo how do you keep the alarm active against the thugs who are using the five finger discount this holiday season??? Use a spare!! Okay, okay, Maxwinch, I know it's not the right size battery, but it helps in a situation where you have to park your Q outside because the garage is occupied by your Subaru Forester whose head gasket job is taking forever!!!
It was from my old home alarm panel... works just fine as a backup....
And here is the way to keep it charged during the day....
The only part that sucks so far is the fact that I had to go to Home Friggin Depot to buy a whole screwdriver set with all size bits just to get my hands on a T-20 security torx bit.
