Philsnotfalling »
https://forums.nicoclub.com/philsnotfalling-u10849.html
Mon Jun 21, 2004 6:12 pm
If you don't complete the circuit for the power windows none will work. So yes you will need to keep driver side power to maintain the pass side working. Is your regulator still good? I get used junk yard "stuff " all the time at work and usually doors come with regulator and hinges and all that other fun stuff. if the rocker was hit and the door won't close, does it close?, well that usally means that a body pull to the pillar is needed... I dunno though b/c I'm not in front of the car.
Tip... to make a power window go up and down with out a battery in the car.
-detrim door-Find the regulator plug from the wiring harness in the door-unplug-using the plug on the regulator side connect one female connector, with length of wire(other end exposed wire) attacthed, to one prong inside the plug-repeat for other prong-get a car battery or jumper box-touch one wire to negative side of power source-touch other side to positive side of power source-window will either go up or down now-to reverse direction of window, switch the wires
if your regulator is good this will work... if you do it rightIhope this is what you're looking for, some more explination about your situation would be nice.
