apreciate the response. I checked all the fuses and they are fine. The doors work fine with the FOB and the passanger door works fine when you push the button on the handle. It might be a bad connection but where would I look? Inside the door pannel You think? ThanksQR25DE wrote:Could be a bad connection or fuse, although I assume if it was a fuse none of the doors would work. I'd check the fuses anyways.
I checked and it doesnt but I heard something inside the door that sounds loose. i will check it out, thanksAlexN09 wrote:hey check and see if the little screen is trying to tell you to press your brake to turn the car on. My car constantly thinks that I'm in the car trying to turn it on when I'm standing outside. If I step a foot further away or put my hand over my keys then I can lock it.
I want to thank everyone for your help. I found the problem!!!!!. I took the panel off and the metal cover that holds the window mech and found that the wires that go the the handle were not inserted in their clips(there are 2 of them) and they were hanging freely in the path of the mechanism which lead to them catching the glash and were torn off. Hope this helps someone else with the same problem. Thanks again for the help and I trully appreciate everyone @ Nico ClubQR25DE wrote:Could be a bad connection or fuse, although I assume if it was a fuse none of the doors would work. I'd check the fuses anyways.
Thanks Bud, Now if I could only fix the AC Ill be set. I think its the AC relay because there is no Voltage going to the compressorAlexN09 wrote:Awesome! Nice job fixing it yourself
