yodawill2000 wrote:Even though its only that door it sure sounds like the timer.Something is telling the lock solenoid to lock.
I appreciate the reply yoda. I read through every "door lock" thread in the J30 section. I'm about to go hit it HARD with lubricant and see if that doesn't help.
I was totally throw off by the fact that it's just the driver door and that it does work for unlocking and locking at times. It has been happening randomly since a week or two ago. I couldn't unlock it and get out one day. I would unlock it and then it would re-lock itself. I had to roll down the window...put the key in the door and unlock it and that unlocked it fine and then I could open it. Then I went about another week with no problems.
Last night I looked outside and noticed an interior light was on and I knew I hadn't left anything on. I went out there and the door latch wouldn't close and it was being strange again. I took the door panel off and at some point in time it decided to behave and when I closed the latch with a screwdriver it stuck (which it wouldn't do before since it wouldn't stay closed). So I closed her up and decided to wait until it was light out today to mess with it.
I guess maybe replacing the door lock timer would be worth a try based on the much less time it would take to do. Then if that fixes it I'd be happy I didn't have to do the harder, more time consuming work. Problem is...although fuzzycats (Carlos) said it was $60 from somewhere (TJ???) it's $125 from infiniti parts usa. That's a little steep to replace something that isn't broken to possibly save me time. I'd be willing to spend $60 though. Any ideas where I could get it for that price or where Carlos was talking about? Thanks.
