ckau wrote:........There is a harmonic vibration in the drivetrain that comes in at approx. 1700rpms and will fade away around 2200 to 2500 rpm. Any suggestion as to what I should focus on?
Transmission mount (AKA 3rd engine mount) and the pair of exhaust hangers mounted to it. If they've never been replaced they're due. After that then look at the two engine mounts and the drive shaft (if it's been removed in the past).
transmission mount R&R is an easy DIY and the only special tool needed is a 2nd jack to support the rear of the transmission while the mount is being replaced. Do a couple of searches (transmission mount, transmission mount, exhaust hanger) and you'll find all the info needed to complete this job.
