ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Thu Mar 30, 2006 5:32 am
well, just a tad after 206,ooo miles my car starts to vibrate while going down the road.
...like you're inside a washing machine & it's on spin-dry...
I was driving back from my sis when my daughter & i started to notice a slight vibration, then progressively getting worse.
@ 1st, i thought it was a flat tire & looked to see-- nope. then, i thought if i had just a tire imbalance cause i feel the vibrations @ higher speeds... Ok, i'll just get my tires rotated on the weekend to see if that was the problem
then, it got more pronounced @ all speeds & when shifted to neutral to coast, like i'm goin over a couple of mini speed bumps. I didn't want to drive all the way home to Bordentown from Deptford, so I took a detour & limped this back to parents' driveway in Cherry Hill until i have time to look underneath on the weekend. anything above 45 mph is just too much vibration.
when i pulled off 295 to take a quick look @ my tires/under engine/undercarriage, I didn't notice anything wrong. A cop stopped by to shine his spotlight so I can see underneath my car (it was 1030 2 night), while my NICOtot sit in the back seat, waiting to get home...
soo, going down rte 38 w/ flashers on to announce that i'll be going slower than the speed limit, i limped it to the driveway.
I just need some ideas to look for/confirm my probable causes so when I do go back to look underneath, i'll have some plan. (no internet there).
I checked the oil levels n stuff under da hood; all good. when started and standing still, it's idling smoovly & revs steadily. no signs of engine misfire...slight vavle cover leak
trans: it shifts smoovely w/ no grindage or anything sticking. this was a replacement transmission from a 91 that was installed summer 2004 when my original died on me @ 197,000 miles... i'll check/ change fluids this weekend. of course, i'll check the differential and change the fluid as well... it's due this spring.
tires: ole pepboys futura gls 205/60R15 still have good tread on them... thought the vibration was from 1 or more of them since I used tire plugs to quickly repair nail holes on tread area... <shrugs> will rotate them & see...
I'm guessing it's a driveline vibration: soo i'll check the u joints & driveshaft carrrier bearing on saturday... just want to confirm that the u joints aren't serviceable?
anything else I should keep an eye on?
thanks
