nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Fri Feb 18, 2011 11:30 am
First off sorry for the long post as Im just trying to bounce ideas around. Ok, for the basics, 92 300zx 2+2 auto, all stock except for cone filter and ptu relocation.
Issue: this is all under load, idleing the car shows no issues, no missing or roughness
From a standstill the car is fine goes from first to second without any issues at all throttle range. It likes to really bog down when I dont stop completely and try to hit the throttle 1/4 to 3/4ish till roughly 3000 rpms then it gets up and goes, like it shifted to fourth gear and wont down shift. if I barely touch the throttle it has decent response, but shifts before I can really get up to speed, almost like its starving for fuel. If I full throttle it downshifts and goes, it has no problem going to redline why I don't think its a fuel delivery problem. Timing is set at 15btdc
Another issue, the idle, the stupid idle. warmed up the car, disconnected the connector for the idle, and I was able to get the idle down to 700ish, but the minute I connected it back up, it jumped up to over 1000rpm. Any ideas?
things i have done:
replaced all gaskets, seals and so on
replaced-TPS, CTS, pcv valves, all hoses(and I mean all fuel, coolant, vacuum), plugs(pfr6g-11, got these from conceptz), timing components, VTC springs, O2 sensor (I have to splice the wires, pretty sure I didn't mix up the white wires, but not ruled out), and Detonation sensor/wiring
Cleaned AIV or AAC which ever it is behind the plenum and tested all good and all connectors
Injectors tested 12-14 ohms cold, have not tested them hot,
I know I am missing a few things, so if I remember, Ill post it
The TPS: Even though this is new I have my doubts its working correctly
Adjusted it .45v closed and came to about 4.4v open.
Here is the odd thing, I adjusted it the first time to .45, opened the throttle and when I closed it the voltage changed to .52, reapeated and it went up some more. So I adjusted it again, yes I made sure it was tight during the opening of the throttle, same thing, I did finally got it to stay at about .45, but still didn't like the adjustment.*I honestly think this is huge factor of the issues*
I don't believe I have a vacuum leak, its not ruled out though, but looking at the trouble shooting in the FSM, everything points out to vacuum leak, so it is a possibilty. I did check the ecu and good old code 55 came up, tonight I will check out mode II, see what comes up. I have not tested the MAF sensor, everything "looks" good, but doesn't mean it is.
Guys I'm lost here, is it possible the trans could be causing all the issues? Have not pulled the codes for that. I really suspect the TPS because of the throttle response, maybe Ill put the old one on and see if it changes at all. Ill take any ideas and let you know if I tried it out. Thanks in advance.
