Amays U G37S »
https://forums.nicoclub.com/amays-u-g37s-u167091.html
Mon Sep 27, 2010 1:24 pm
I use it. I've noticed however, if you do a 3rd gear, or 2nd gear pull in the car, at low speeds, and then switch out of DS mode into regular Drive mode, the car may shift a bit uneasy at first, however it will pick up very shortly after and shift correctly.
I use DS mode on the interstate, to shift down and pass, or just do a pull. Also on back roads when I just want to do a quick pull to 60. I have switched it to DS mode, and used to padel shifters to shift gears till 5th. Everything went smooth as glass.
On older models (before 2008) the system was kind of slow in responding, so it wasn't used as frequently. On our 2008+ models, the system is very quick at shifting. Long term side affects could see some wear on gears, just as a manual would? Im not for sure on that, so don't quote me on it.
I am also weary of screwing up the transmission, but buddy, you shift it into 3rd at 80mph, push the rpms into 5k, and slam the gas, that car will scream into 7k, and shift into 4th, and its a freakin BLAST! I love it.
There are a few people that use it a lot more then I do. I just love doin 40mph-60mph 2nd gear pulls, or a few 80mph, to 120mph, 4th gear pulls on the interstate.
You may want to dig into it deeper, and try to find some long term side effects. I've experienced some bucking in a loaner shifting from reverse to drive at almost a stop, when backing out of somewhere, and this could be a long term side effect of using DS mode frequently, not for sure.
Post up if you see any complications.
