drive shaft
Ammi
I've noticed a very slow leak coming from front drive shaft. I'm thinking one of the transmission seal is bad. Does it require dropping the transmission?
ARKQX33V6
Check first the lines going to the cooler in the front rad. The lines have crush washers at top of transmission and the passenger side of transmission. With a flashlight see if they are leaking. If wet around the terminations, you may have to repair or replace the crush washers. To repair take apart, take washers out, then hammer carefully to straighten them out then reinstall torque down and test, to replace buy new put in.
Sometimes just tightening the connection works. Keep an eye on it for a while.
If a seal is bad, the shaft has to be removed but you may be able to replace the seal, depends on how agile you are and the amount of room to do the job. Make sure to check the level of fluid until repaired.
A temporary fix if the seal is just wet is to wipe grease over the seal, the grease will act as a dam until you get around fixing it. Another product that I use is Duxseal available from electrical wholesalers. This stuff never dries out and I use it for oil, water, vacuum seal and as a dielectric...
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
thanks for info ARK, I have a very very small leak also, not worth spending the money on it now unless it gets bad. will try to find some Duxseal.
ARKQX33V6
Here in Ontario the Duxseal is sold in Electrical Wholesalers by the Kilogram. I still have about 1 lb left in my toolbox from over 30 years ago. It can be used in vacuum, water, oil, leaks if backed up by some sort of mechanical barrier. Example would be Duxseal wrapped with black tape.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
ARKQX33V6 wrote:Here in Ontario the Duxseal is sold in Electrical Wholesalers by the Kilogram.
Just curious: Where in Ontario are you?
I'm in Ottawa.
ARKQX33V6
Orangeville
