float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Oct 25, 2006 2:12 pm
It CAN work, but you don't want to use it if you don't have to. The KA motor produces a decent amount of torque, because of this, Nissan used a dampener on the KA driveshaft to make the car drive smoother. This Dampener cause 2 problems.
1st- Clearance. There is a dust sheild on the CA trans that won't allow the KA driveshaft to fit into the CA trans all the way. You'll have to beat it off with a hammer, as it's just slid into the trans.
2nd- Power. There have been a few members who have had problems with this dampener tearing itself in half with increased power. In stock form, or even slightly modded you should be OK. If you do a lot of burnouts or clutch drops, it may not last though.
