Are you sure its coming from the driveshaft? Is it possible the shake could be from a misfire under load? Like I stated earlier an exhaust leak will cause a rumble which can be misdiagnosed as a shake. Have you tried driving it at higher speeds? Is it still there? Is it only at the lower speeds under medium to heavy acceleration?Shoey2 wrote:all the bushings are good and mounts. i put the carrier bearing in myself about 3 months ago. easy to change. marked the shaft alignment before i took it out so I'm stumped. everything seems to be moving smooth. i wanna do the 1 peice shaft upgrade but im not sure how much accelleration change is noticable.
that sounds pretty close to what im experiencing booster. once you get your new 1 piece shaft in let me know how it turns out. i might be needing one too.canadian booster wrote:i haev the same problem by the sounds of it, i've got a solid driveshaft to put in the Z this spring when the snow is gone, hope that fixes it. i notice the shake the most between 45km/h and 80km/h .. it is less noticeable at higher speeds, you too?
