vrizi »
https://forums.nicoclub.com/vrizi-u212290.html
Mon Dec 31, 2012 6:18 pm
not sure if it is the same on the s13 as s14, but on mine(96 s14) there are 4 bolts from the drive shaft to the rear diff. I believe these are 14mm. they will be pretty tight. make sure your e brake is on so that there is no movement when you loosen them. You want to loosen the nut side, not the bolt side. It will be easier to come off this way. Once you get those off there will be 2 bolts going up holding the carrier bearing. remove those, and the shaft should slide right out of the transmission. I hope this helps you.
