CSUPUEBLOTIM wrote: to impact guns.
...If you would of read, then you would of seen this:
J240sx wrote: Also a socket wont be able to fit on them.
No way an impact gun would fit in there. But I do to the impact guns.
Justin35ll wrote:Loosen the NUTS not the bolt head. It will come off muchhh easierThen the carrier then slide the shaft out.Then replace seal, make sure not to scratch the surface when pulling the old one
Sorry for the miscommunication, but I was trying to turn the NUTS and not those bolts. I looked at those bolts and thought to my self, "would be way easier to turn the nuts." Next time i'll pull the parking brake even tighter so the drive shaft won't move as much, and put the car in gear.
If the leaks are forming here, then the rear seal must be done for, right? Took out the filler plug and gear oil came out, maybe my leak was being caused because of an overfill? Well, I've topped off the transmission with some redlline and will see If it keeps on leaking from there.
Check out how my exhaust burned up all the leaking fluid.
