drive shaft... from pst..??
240SXplan
Car: 1990 240SX
Any one know the shop in Florida... that makes drive shafts...??I got the info from one of the guy here...
PSTDS. com....??
anyone used them for a drive shaft?? for rb25det.. swap..??
any input would be great.. about their service and product..??
:ylsuper
thanks,
plai
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
there is already an open class-action lawsuit.... there is a thread here somewhere.
240SXplan
Car: 1990 240SX
i know.. i ssaw that.. i got it,...
any word on PSTDS.... ??
Imissmyturbo
Car: Car's, Turbo's, sking
If It's the place I think it is they told me it would be $800 for a custom driveshaft and it would be 3-4 weeks. He would only make it using Carbon fiber. I then called a place in Vegas and got one for 297 shipped and I got it in less then a week. It is just a steal driveshaft.
BoostFab
Car: S13cp, S13fb, S14z
damn $800?
plai xiong: any a local drive shaft shop can custom make you a drive shaft and would be a fraction cheaper.
240SXplan
Car: 1990 240SX
that place in Florida said he'll do it for me Steel.. $350.00allium: $450.00 and Carbon fiber.. $550.00.. nothnig about shipping yet..
In Minnesotathere are some but they have not give me a possible.. answer.. they don't seem to know what the heck I'm talking about..they are mostly OEM... Not much custom.. If custom it cost between $300- $500 and we have to possibly provide the parts.. So it might turn out to be $800.00..
Nissan 300ZX drive shafts go for $900.00 up here.. in Minnesota..I have not be able to find any used drive shaft for a good price.. nothing under $100.00..
Soo.. IMISSMYTURBO...:: where is this place you are taking about..?? give me the number.. and address?
plai
Imissmyturbo
240SXplan
Car: 1990 240SX
yeah.. i called them up.. and.. they ask me a couple questions...but what i need to know from you.. is.. your..
demensions... I measure.. from the 4 bolt on dif end to the transmission slip gill... 44.. inches.. and.. count 30 sprines..
how about yours...
thanks,..
az240
I got mine at a place here in az...it cost me $140, and they did it in 5 hours....my shaft was 40 inches from seal to flange
240SXplan
Car: 1990 240SX
interesting.. I did the same measurement... too.. and got 44 inches..
remember this is for a drive shaft that fit on to a rb25det transmission.
what mounts you use and cross member?
thanks
az240
R33 x-member, and rb25 motor and transmission in a 93 coupe
Boardman
I got my one-piece custom steel driveshaft made locally near Chicago at http://www.shafts.comTotal was about $375.If you plan to use them..... then I need to provide the list of u-joints/input shafts they had to order and list it in this thread because otherwise mine was the first and last 240/RB25 shaft they will ever make.....Usually a custom domestic shaft takes them 1-day. I walked in on a Tuesday..express shipped the parts from their warehouse/supplier on the west coast...and had the shaft on my car on Thursday.Greaseable joints recommend greasing every 3k miles- should last 100k miles. I could only dream of making enough hp to destroy this driveshaft.
I modified the stock RB25 mounts and R33 cross member = free- no hitting hood- -steering shaft/02 housing clearance fine--no front oil pan/sway bar contact--shifter perfectly sitting center to center in shifter hole-Center of front U-joint with RB25 input shaft bottomed out inside the transmission...to...face of differential = 41 inches for me (S13 hatch with longer '95 J30 LSD).
240SXplan
Car: 1990 240SX
how do you modify your r-33 mounts and Cross memebers?
