fernandoh »
https://forums.nicoclub.com/fernandoh-u153769.html
Sun Aug 08, 2010 3:27 pm
My 2003 automatic 4WD has a clunk in the rear U joint of the drive shaft (a very long piece with only 2 U joints). The clunk is noticed when slowly braking in traffic conditions and is due to some extra free play in the U joint at the rear, close to the 4 bolts differential linkage. I circled the problem (no clunk when you brake in neutral) and is related to changes in the relative position of the diferential and the shaft (bumps may produce similar sounds). Then I put a new ordinary joint in there and the clunk was solved for some 1000 km. It returned soon and new better (no Nissan) joints of a reputed brand failed since day one. Reading somewhere I got the information that the clips that hold the U joint in place can be of different thicknesses to keep the free movement of the joint in the range of 0.1 mm or less. But I can't get that parts around here and the new parts only has the standard clips. Any ideas or places where to find that oversized clips? Other aspects?
