http://www.courtesyparts.com/i...1.gif
Hello all.I put a new clutch in my KA powered 240 a couplle days ago. It was the first time in a while that working on one of my cars that wasn't really that fun.Anyways, when I was putting the drive shaft back in, I was noticing that the center bearing was not centered with the bracket and bolt holes. (The rear of the drive shaft was already bolted up holding it back) So to get it in straight, I loosened the rear drive shaft bolts to allow it to come forward. Then tightened it down straight and centered. Well everything seems good now but it seems like there is a lost of power. Unless the clutch has any thing to do with it, having the center bearing always being pulled forward is the only other thing that I could think of that that might be the problem. What ideas do you guys have?
