drive shaft bushings
stash420sx
I had my 240 on a lift at the shop the other day and I noticed the bushings were pretty worn around the drive shaft and such. Anyone replaced this stuff, and know the names of the bushing parts i need?
NISTECH
the one in the center of the shaft ? this is called a center support bearing. check the 2 tension rods up near the front going from the lower control arm to the lower radiator support.
