Drive mode selector unresponsive [FIXED - replaced knob]
Neversurpassed
Car: M56x
I purchased a 2012 m56x about 7 months ago. The previous owner.... well let’s say I am doing work. I have a rattle under the car and I figure it’s the heat shield. That’s what it was on my m35. The problem that is bugging me is the drive mode selectior does nothing. I thought I could be a fuse but then I figured something else would also be out not just that. Does anyone have any idea what it could be? No matter what position it is in I get no induction on the dash.
Reason: update with solution
emm3seven
Car: 2011 Infiniti M37x w/Tech + Touring
The factory service manual has a dedicated section for the drive mode selector, complete with detailed troubleshooting flowcharts. Some of those steps require a CONSULT-III but some do not, and you can probably rule out some basic problems without it.
The manuals linked via this site don't appear to have the DMS section for 2012 models, but the 2011 documentation should be close enough:
http://www.nicoclub.com/FSM/M/2011/DMS.pdf
Neversurpassed
Car: M56x
Thank you for your time and response I will try it out.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
When you rotate the selector it should tell you the mode your in between the two dials, aka speedo and tach.
If that doesn't appear i would first attempt a disconnect of the battery for about five minutes. It could of had something freeze up.
After that it would need a deeper looking into but I would definitely start with that.
Good luck
Keep us posted
Neversurpassed
Car: M56x
Malbec 56 Beast wrote:
Sun Mar 24, 2019 8:58 pm
Good luck
Keep us posted
I tried that and it still does not work. I disconnected the battery, left the doors open and operated switches in the car just Incase any capacitors held any residual power. When I reconnected I still do not get any indication that the switch is changing drive modes. Thank you for your response
Ilya
Mine stopped working when I blew the 10amp fuse labeled 'elec. parts' in the fuse box by your left foot. Check your fuses again. A lot of other stuff was affected for me, but I'd just double check. I think it was the 4th fuse down from the top on the left side.
Neversurpassed
Car: M56x
Thank you I will try my fuses again today and reply. Hope it’s that simple.
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
On your heat shield rattle - I've had it a couple of times. One time it was a loose heat shield bolt, tightening it up fixed the rattle. The other time it was little rocks and pebbles after winter that were on top of the shield and causing the rattles. I used a refrigerator coil brush to get up their and clean it off.
Neversurpassed
Car: M56x
Ilya wrote:
Mon Mar 25, 2019 7:11 am
Did the fuses again you have to be a contortionist to get to them but they all checked ok. I will try and find the rattle again I checked the shields on the under side will check the engine shields next time. Thank you once again
Ilya
So the selector is still not working? Odd, not sure what else would control it.
Neversurpassed
Car: M56x
Ilya wrote:
Wed Apr 03, 2019 7:49 am
No it’s not. The DCA works I was a little over zealous in the highway ran up on a truck to fast and the pedal pushed back. So I know that part works
Ilya
Very strange...at this point I'd say check your engine bay fuses too, there are a few...this car is weird and some things are tied into others that you wouldn't expect.
Neversurpassed
Car: M56x
Ilya wrote:
Wed Apr 03, 2019 6:07 pm
I checked them they were fine. I ordered a new selector switch. It was about 70 dollars just waiting on it to come in.
Neversurpassed
Car: M56x
Works, replaced the selector switch. thank you everyone for your continued help
satown210
Car: 2012 Infiniti M37
2005 Nissan Xterra Off Road
I bet with the proximity to the cup holder. The selector switch might have gone for a swim at one point.
