numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Wed Jan 11, 2017 5:51 pm
We're sorting out another vehicle for sale. This time it's a 2004 explorer 4.0 sohc v6, 116k miles. Misfire in cylinders 2 and 6, new coil pack solved that. New egr solved a faulty map sensor (it's one whole unit, couldn't replace just the sensor).
The issue we're stuck on is with the drive by wire system. Key on, engine off the throttle plate opens and closes fully when the pedal is pressed. Once the engine is started, idle blows, the pedal seems to have zero effect on the throttle, and it eventually stalls.
We have a good relationship with the employees at our local advance auto, so we checked a new tps to no avail. We're at a loss as to why everything stops working once the engine is started. It doesn't help that electronics are beyond our comprehension.
Any ideas, or things to check?
Side info, I personally picked this explorer up from the Bronx and drove it back to CT. It drove fine, but the cel was on. If I floored it on the highway, the cel would eventually start flashing, and it would cut ignition until rpms dropped. After that cel would go back to solid and I had control again. When I got home, scanner informed me of the misfires.
I swapped plug wires to rule them out, but nothing changed and I was sure it was the coil since 2 and 6 share the same coil on the pack.
A couple days later, I went to drive it 1 mile to my buddy's house and thas when the throttle issue first arose. I limped it there and we changed the coil. After that is when the map sensor popped up.
I know it did a lot of sitting, months at a time, but this is crazy.
