AznJohn22 wrote:How long does it take to change out a drive belt?
0.8 hours according to the guide I have.
Here are the steps from Nissan:
Removal and Installation
REMOVAL
1. Remove front wheel and tire (RH).
2. Remove front fender protector (RH). Refer to EXT-22, "Exploded View".
3. Hold the hexagonal part in center of drive belt auto-tensioner
pulley with a box wrench securely. Then move the wrench handle
in the direction of arrow (loosening direction of tensioner).
CAUTION:
• Avoid placing hand in a location where pinching may
occur if the holding tool accidentally comes off.
• Never loosen the hexagonal part in center of drive belt
auto-tensioner pulley (Never turn it counterclockwise). If
turned counterclockwise, the complete drive belt autotensioner
must be replaced as a unit, including the pulley.
4. Insert a rod approximately 6 mm (0.24 in) in diameter such as
short-length screwdriver into the hole of the retaining boss to fix
drive belt auto-tensioner pulley.
5. Loosen drive belt from water pump pulley in sequence, and remove it.
INSTALLATION
1. Hold the hexagonal part in center of drive belt auto-tensioner
CAUTION:
auto-tensioner pulley (Never not turn it counterclockwise).
If turned counterclockwise, the complete drive belt
auto-tensioner must be replaced as a unit, including the
pulley.
2. Insert a rod approximately 6 mm (0.24 in) in diameter such as
short-length screwdriver into the hole of retaining boss to fix drive belt auto-tensioner pulley.
3. Hook drive belt onto all pulleys except for water pump, and then onto water pump pulley finally.
CAUTION:
• Confirm drive belt is completely set to pulleys.
• Check for engine oil, working fluid and engine coolant are not adhered to drive belt and each
pulley groove.
4. Release drive belt auto-tensioner, and apply tension to drive belt.
5. Turn crankshaft pulley clockwise several times to equalize tension between each pulley.
6. Confirm tension of drive belt at indicator (notch on fixed side) is within the possible use range. Refer to
EM-16, "Exploded View".
