drive belt change
slowroll
Car: 2005 g-35 sedan
trying to change drive belts took off skid plate and found tension bolts once bolts are loosened belts do not loosen is there other steps i'm missing
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Yes,check Nate's HOW TO threadhttp://forums.g35club.org/zerothread/336182
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
just need to loosen the nut on the tensioner first...
then you can use the adjusting bolt to loosen everything up.
thats the extent of it.
