drive axle
dann
Car: 1990 240 sx
hi my name is danny and i have a 1990 240 sx w/ a/t trany and i want to convert it to 5 speed. my question is can i use my a/t cross member and drive axle to 5 speed trany. thanks
themadscientist
no. The five speed and auto crossmebers are 180 degrees different, you will see what I mean when you see them side by side. the driveshaft is different too. Make sure to get the drivehaft and crossmember from the five speed car.
lofapoo
Car: Toyota sedan
You need the front half of the driveshaft for the 5spd swap, but at that point you might as well get the whole thing.
The crossmembers are entirely different as stated above.
sbird1
Car: 2006 BMW 325i
I still have a M/T flywheel for sale if you want it!
Dattebayo
This should go to the 240 section
This is the General section
Read the forum guidelines
Welcome to NICO
