Drive and Passanger Window is getting Cut by inside the door?
9095240SXDUCK
Car: 240SXs
Ok
I have notice my HB drive door and passanger door window have 2-3 inch deep cuts where the nissan emblem is on the glass.
I have a set of spare windows. But I am trying to find out what is cutting it? How Do I fix it?
Thanks
I try to search but did not see anything close!
You'll want to completely disassemble the door - there's obviously something broken inside that is scratching the glass.
Once you find it, you can fix it and put in your new windows!
9095240SXDUCK
Car: 240SXs
I have disassemble both the door about twice already, I don't see anything. that is bent or broken! I just through maybe someone here has the same exprince on their car. Or maybe someone can tell me what to look for! I just can't find anything. I even try to compair each parts from each other to see do I see anything!
9095240SXDUCK
Car: 240SXs
bump
nismofly
Car: 89 Nissan 240SX Hatch
i get some pretty good scratches too, im wondering if my windows out of alignment or something
mikeh16
Car: s12 200sx
I've seen my windows become scratched like that and it was caused by small rocks becoming caught in between the rubber seal and the glass. When I took the window off, they fell out and my problem was solved. But, I guess that doesn't help if your windows are still being scratched.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
YEs is that freaking little rubber "stabilizer" thingie, is like a little sponge and it gets a lot of dirt and particles stuck into it by the window going up and down, specially if you live in sandy or dusty areas. All you need is to slide that rubber piece out of there. Is easier if you take the door trim panel off.....
nismofly
would this cause the windows to go up and down slower than you would normally expect? its been like this since i got the car so i dont know if its just the same thing in every car, or if my window motors are wearing out a bit.
amolao
wearing out, specially if is an '89......
9095240SXDUCK
Car: 240SXs
CoolThanks Guys I will make sure I clean it out when I take my doors apart again!
Thanks
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Check for sand or something in those padded guides inside the door along the top.
