OwnerCS wrote:Have you thought about a Fumoto Valve? I believe it has a different style washer that might seal.
I'd like to have Fumoto or a Quick drain valve for Oil, and Trans Fluid.
http://www.fumotousa.com/
Nice but I am paranoid and fear someone might find such a valve and drain the Engine or A/T oil, without me knowing it till its too late.
AZhitman wrote:Infinitiguy19 wrote:Their is a left over crush washer burned into the drain plug but like you said that is not removable. Other than that the drain plug is flat.
No, the old crush washer is the culprit. Get it off there. It's soft, so you'll need a pick and a pair of wire cutters.
Tightening it down more isn't helping.
Like I said the old crush washer is burned in as in part of the drain plug and I think sanding it off is the only way its coming off. Plus it does not look like its very thick. It simply looks like some of the copper (The OEM drain plug washer is made from copper) is burned on to the metal drain plug.
Lokim wrote:Get a new plug, washer, and finish it off with a little PTFE tape.
The factory never used PTFE tape and never will I in this case.
Q451990 wrote:
Re: Dripping from A/T drain plug despite using OEM crush was
by AZhitman » Today, 1:20 am
Exactly Heath.
Well back to digging my car out of the 1.5 feet of snow.
