diggles240 »
https://forums.nicoclub.com/diggles240-u89507.html
Wed May 07, 2008 7:55 pm
icemhan_21: have you drilled the hole in the bellhousing for the CAS yet? i am running into the same issue on my swap. i am concerned about the precision required for the placement of the CAS. i know the sensor is an inductive type sensor that sends a signal to the ECM which, in turn, uses said signal to determine when to fire spark and inject fuel for combustion. i am uncertain of the allowable tolerance with regard to the sensor position in relation to the flywheel surface. can somebody, anybody, help out on this? this has been bugging the sh$t out of me.
thanks,kevin
EDIT: thanks for the dimensions motoman
