Drilled & slotted rotors question
J30inthe sun
Car: 1997 J30
Has anyone tried these?
http://stores.brakeplanet.com/...otors
The price is right & they have a lifetime warranty against warping.
driverdriver
Car: NICO's longtime resident Canuck!!!
Make sure you read the fine print on the "lifetime warranty".
The J is a heavy car and most aftermarket brake rotors will warp gaurantee or not. Stick to Nissan OEM or really high end aftermarket like Brembo.
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
driverdriver wrote:Make sure you read the fine print on the "lifetime warranty".
brembo makes rotors for our J???ive never seen them...if so do they make a caliper upgrade as well???
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
kbflip02 wrote:brembo makes rotors for our J???ive never seen them...if so do they make a caliper upgrade as well???
Brembo rotors are $52. each for fronts at rockauto.com
kbflip02
2006 Infiniti G35x
and the rears?
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
kbflip02 wrote:and the rears?
No Brembo rears they have Wagner $32 and Centric $50
J30inthe sun
Car: 1997 J30
FYI, Brembo rears can be had here:
http://www2.partstrain.com/sto...Nty=1
I just ordered the Raybestos Advanced Technology Rotors from rockauto.com for $17.35 a piece minus a 5% discount, total with shipping was @ $49.00 for 2.
See description here:
http://www.raybestos.com/wps/p...otors
The Raybestos part # is: "RAYBESTOS Part # 96317"... NOT THE ONE MORE EXPENSIVE ONE ENDING WITH AN "R" (that is actually the cheaper grade) .
I called Rockauto & Raybestos (good luck finding the regular long distance phone # & not the $$$ 900 #) to double check. Raybestos' website showed that part # as a solid rotor but the Rep I called at Raybestos said the part # I gave him was for the vented "Advance Technology Rotor". In fact he said that was the best Raybestos rear rotor they made for my J.
On another note, after much googling "drilled rotor advantage" , I believe that good quality solid vented rotors are the way to go, to many mentions of cracking with drilled rotors (unless the rotors are cast with the holes in them). I will be replacing the front rotors with Brembo next month with AKEBONO pads Part # ACT587 {ProACT Ultra Premium Ceramic Pad}.
