Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Thu Sep 16, 2004 4:11 pm
I don't drive all that hard, and my rear drilled and slotted rotors cracked, one day, while in heavy traffic, this summer.
It was primarily caused by my left rear caliper pin sticking, and the pad rubbing non-stop. It would be several hundred degrees hotter than the right one, when I would stop & check them with the IR temp gage.
I would not be afraid of using them, if you change them your self, because they may only last about 30,000 miles, where the OEM's will last 3 times that, with proper care.
