$125 for a full day of drifting!
$10 for passengers
Tentative schedule, subject to change:
Gates open/Tech starts at 7:00am
Driver’s meeting/ Parade lap at 9:00am
Let the drifting commence 9:15am-5:00pm
This will be open drifting, no run groups. Come on and off the track as you want. This will provide more seat time than you can handle!
This is a perfect opportunity for all skill level drivers from first timer to pro to get out, practice, and have fun on an amazing track!
Make sure your car can pass basic tech inspection, nothing fancy here, same basic requirements as any laid back track. If you have questions about tech make sure to get them resolved prior to showing up. There will be no refunds, even if you don’t pass tech.
Battery must be secure and positive terminal covered.
Seats and seat belts/harnesses must be safe and secure.
No excessively leaking fluids.
All lugnuts must be present and secure.
All loose items must be removed from car and trunk.
Convertibles must have a roll bar or hardtop.
Use common sense. If you have issues that will make your car dangerous or unsafe in any way, fix it before showing up.
Wear closed toe shoes and long pants.
There will be some helmet rentals available but I recommend bringing your own just to make sure there’s one available in your size. DOT helmets are allowed.
This is an AWESOME track to drift on and very laid back too. No excuses, you have 2 months to ziptie your pile together before this event. Let’s get a good turnout so we can make this a regular occurrence!
