please don't post if you have no idea what's going on....with life.
MxExUx wrote:if you do an LS1 swap you will completely change the balance of the car and it won't drift or even drive the same. Unless you have the time and money to do some serious suspension tuning.
good post on the
http://www.hinsonsupercars.com that'll give you the REAL facts on the weight etc for the ls1 swap. Depending on what you do, your setup may actually weigh a little less and power will be like 51/49 or something...usually, but each swap is different.
As far as drifting an LS1 FD, I owned one so take what I have to say for what it's worth.
1st, the RX7 isn't a great drift car to start with, it's twitchy and hard to keep consistent, fact of life. Not saying it CANT be drifted or cant be drifted well...but it's certainly not a beginners drift car.
2nd, the LS1 has a LOT of torque, especially at low rpms, which will break you loose super quick but will also make it more difficult to control due to such precise throttle work required.
Enjoy
